[gdal-dev] Which formats are just flat binary files plus a header?
Frank Warmerdam
warmerdam at pobox.com
Thu May 3 20:20:51 EDT 2012
On Thu, May 3, 2012 at 8:35 AM, Jonathan Greenberg <jgrn at illinois.edu> wrote:
> Gdalers:
> I'm working on some parallel processing routines via rgdal and R, but
> thought this question was better answered here. I'm trying to find out
> which raster formats are simply a flat binary file an a header. ENVI is the
> one that springs to mind. We're trying to work up which files can be
> "natively" written as flat binaries where all we have to do after the file
> is written is setup the correct header. Thanks!
Jonathan,
In addition to those mentioned, my favor GDAL supported raster
raster files + ascii header are:
PAux (PCI with .aux - my design!)
EHdr (ESRI BIL with .hdr)
VRT (you can use a GDAL VRT to describe a raster raster file with
*full* GDAL metadata, etc)
Best regards,
and watch the world go round - Rush | Geospatial Software Developer
