[gdal-dev] gdal.AutoCreateWarpedVRT returning different results
than osr.CoordinateTransformation
Billy Newman
newmanw10 at gmail.com
Sat May 5 17:22:46 EDT 2012
Still very confused.
I have a tiff file. I want to get the metadata for that tiff but in
EPSG:4326, without actually warping the image. I can use
CoordinateTransformation to do this, but again it gives me different
results than gdalwarp.
I will use gdalwarp later (realtime) to serve out an image. But if the
metadata I store (from CoordinateTransformation) is different than the
metadata when I warp I will run into problems.
gdalwarp gives something like minLon = 30.300001234, but
CoordinateTransformation gives minLon = 30.29988787. I want to gdalwarp
number but without actually warping the entire image.
I am not sure what .vrt file you are talking about.
Thanks again
On Sat, May 5, 2012 at 3:15 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> On 12-05-05 01:19 PM, Billy Newman wrote:
>> Can you think of a way that I can get the same metadata as gdalwarp would
>> give
>> for a warped image without actually warping the image?
> Billy,
> Just open the .vrt and read the corners (that is compute them from the
> size and geotransform). There will not be any actual warping done just
> to get this metadata from the .vrt but you will get the result
> representative of the reprojected image.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://home.gdal.org/warmerda
> and watch the world go round - Rush | Geospatial Software Developer
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120505/e54ebc8a/attachment.html
