[gdal-dev] gdal_translate waits at the end of operation
Kyle Shannon
kyle at pobox.com
Wed May 9 19:23:28 EDT 2012
Sounds like your doing something wrong, it shouldn't hang. Can you share
your command line args or a snippet of your batch file?
kss
On Wed, May 9, 2012 at 5:06 PM, kaarigar <kaarigar at gmail.com> wrote:
> I hope this is the right forum to pose this question to.
> I am using gdal_translate on Windows 7 64 bit to batch convert a lot of
> GeoTIFF files to XYZ ASCII. (I got gdal_translate when I installed
> Geoinformatica tools, based on GDAL version 1.9Dev). However, at the end of
> each conversion gdal_translate just waits - I have to press CTRL-C to wake
> it up so that the batch file can continue to process the next command. This
> very much defeats the purpose of the command line program - because it
> forces the user to be around to press key. Is this expected - or am I
> missing something here? Any help is very much appreciated. Thanks!
> http://osgeo-org.1560.n6.nabble.com/gdal-translate-waits-at-the-end-of-operation-tp4964258.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120509/f2585007/attachment.html
