[gdal-dev] Re: gdal_translate waits at the end of operation
Ari Jolma
ari.jolma at gmail.com
Thu May 10 02:10:17 EDT 2012
Kaarigar is using gdal_translate on Windows 7 64 bit from Geoinformatica
stack, which I've compiled with MingW/MSYS on Windows 7 32 bit.
I just tried similar command line on Windows Server 2008 R2 64 bit and I
don't see it stalling after conversion.
Best regards,
Ari
On 05/10/2012 02:34 AM, kaarigar wrote:
> Here's the command line:
> gdal_translate -ot Float32 -of XYZ -co "COLUMN_SEPARATOR=," n40w124.tif
> n40w124.xyz
> Kyle Shannon-3 wrote
>> Sounds like your doing something wrong, it shouldn't hang. Can you share
>> your command line args or a snippet of your batch file?
>> kss
> View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-translate-waits-at-the-end-of-operation-tp4964258p4964307.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
