[gdal-dev] OGC services requests in VRT?
Paolo Corti
pcorti at gmail.com
Thu May 10 09:00:25 EDT 2012
On Thu, May 10, 2012 at 2:57 PM, Paolo Corti <pcorti at gmail.com> wrote:
> On Thu, May 10, 2012 at 12:49 AM, Ethan Alpert <ealpert at digitalglobe.com> wrote:
>> Is it possible to use an OGC call in a VRTRasterBand?
> I guess you mean a WCS, and I think it is possible, just put the xml
> file in SourceFilename under VRTRasterBand.
> Very quick sample, create a test.xml file like this:
> <WCS_GDAL>
> <ServiceURL>http://nsidc.org/cgi-bin/atlas_south?</ServiceURL>
> <CoverageName>antarctica_satellite_image</CoverageName>
> </WCS_GDAL>
> Now if you export this datasource to a vrt:
> $ gdal_translate -of vrt test.xml test.vrt
> this is the output test.vrt file:
sorry, this is the correct output vrt file:
<VRTDataset rasterXSize="48333" rasterYSize="48333">
<SRS>PROJCS[&quo...........</SRS>
<GeoTransform> -3.1745125000000000e+06, 1.2500000000000000e+02,
0.0000000000000000e+00, 2.8160125000000000e+06,
0.0000000000000000e+00, -1.2500000000000000e+02</GeoTransform>
<Metadata />
<VRTRasterBand dataType="Int16" band="1">
<Metadata />
<SimpleSource>
<SourceFilename relativeToVRT="1">test.xml</SourceFilename>
<SourceBand>1</SourceBand>
<SourceProperties RasterXSize="48333" RasterYSize="48333"
DataType="Int16" BlockXSize="1024" BlockYSize="512" />
<SrcRect xOff="0" yOff="0" xSize="48333" ySize="48333" />
<DstRect xOff="0" yOff="0" xSize="48333" ySize="48333" />
</SimpleSource>
</VRTRasterBand>
</VRTDataset>
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
