[gdal-dev] Re: gdal_translate waits at the end of operation
Thu May 10 11:49:27 EDT 2012
It should be possible to specially implement the CreateCopy for XYZ
format to avoid this.  I'll investigate this.
Best regards,
On Thu, May 10, 2012 at 8:30 AM, kaarigar <kaarigar at gmail.com> wrote:
> Etienne Tourigny-3 wrote
>> Something that is not apparent is that gdal_translate (via driver's
>> GDALCreateCopy()) usually opens the new dataset after creation, and
>> the XYZ file loading is slow:
> That explains it - the XYZ file created is ~4gb in size - it would take it a
> very very long time to figure out the details from it. What I don't
> understand is why gdal_translate would want to open the created xyz file? Is
> there a special build of this utility that doesn't do this?
> View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-translate-waits-at-the-end-of-operation-tp4964258p4965947.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
