[gdal-dev] Re: gdal_translate waits at the end of operation
Frank Warmerdam
warmerdam at pobox.com
Thu May 10 13:17:08 EDT 2012
On Thu, May 10, 2012 at 9:59 AM, Karu Kaarigar <kaarigar at gmail.com> wrote:
> Thanks, Frank. I am not familiar with the gdal development at all. But I
> think replacing the driver binary with this new one wit your change should
> fix the behavior locally for me?
> Kaarigar
Kaarigar,
The XYZ driver is not built as a distinct driver. It is just built into the
main GDAL .so/.dll. If you are using pre-built binaries i may be hard
to incorporate the change. If you are building from source, just replace
the xyzdataset.cpp file.
In any event, you can just run with the gdal_translate you have now. It
will just be inefficient.
Best regards,
and watch the world go round - Rush | Geospatial Software Developer
