[gdal-dev] Updating a single PostgreSQL field from ogr/python
Martin Jensen
martin.martinjensen at gmail.com
Sat May 12 13:43:23 EDT 2012
Hi list,
I was trying to do the following with ogr python bindings
1. Create srclayer from PostGIS based on sql statement
2. Copy srclayer to dstlayer (also PostGIS)
3. Add new field to dstlayer
4. assign value to new field
My code is this:
### Open Database
Driver = ogr.GetDriverByName('PostgreSQL')
db = 'pg:host=localhost dbname=test user=postgres password=secret'
dataSource = Driver.Open(db,1 )
## crate source and destination layer
srclayer = dataSource.ExecuteSQL("SELECT gid,aar,ejd_areal,pris, geom FROM
salg WHERE aar=2010 AND pris >0 AND ejd_areal >0 limit 15")
dstlayer = dataSource.CopyLayer(srclayer,'gwr.dstlayer', options = [
'OVERWRITE=YES'] )
## add field to copied layer
fieldDefn = ogr.FieldDefn('gradient', ogr.OFTReal)
dstlayer.CreateField(fieldDefn)
#outFeature = ogr.Feature(dstlayer.GetLayerDefn())
outFeature = dstlayer.GetNextFeature()
## update the new field
for feature in dstlayer:
outFeature.SetField('gradient',666) ##set this field only
outFeature.SetFID(-1) ## tried to unset ogc_fid so not violating pk
column constraint
dstlayer.CreateFeature(outFeature)
I get the error:
ERROR: duplicate key value violates unique constraint "dstlayer_pk"
DETAIL: Key (ogc_fid)=(1) already exists.
I have a feeling i'm missing something really simple here.
Any suggestions would be much appreciated!
Software:
GDAL 1.9
PG: PostgreSQL version string : 'PostgreSQL 9.1.3 on
x86_64-apple-darwin11.3.0, compiled by i686-apple-darwin11-llvm-gcc-4.2
(GCC) 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.9.00), 64-bit'
PG: PostGIS version string : '2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1'
Best regards
Martin
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120512/de5bd90c/attachment.html
