[gdal-dev] WFS - OGRLayer GetNextFeature - fails
hamidi hamidi at gmail.com
Mon May 14 06:26:41 EDT 2012
hi
i've a question about format of LAYERDEFINITIONFILE.LDF file and the
meaning of entries in this file.
i don't know from where and how can i ask this.
can anyone help?
On Mon, May 14, 2012 at 10:42 AM, Odd Ragnar Lydersen <
Odd-Ragnar.Lydersen at powel.no> wrote:
> Yes, the server is accessible to the outside world.
> But first I must say, that we have modified our server to send the correct
> gml document.
> The problem was that the server only got the < text/xml > part specified
> by the OutputFormat parameter, and not the < subtype=gml/3.1.1 > part, so
> our server bailed out.
> Then we ran into another problem, when we used OGRLayer.
> SetSpatialFilterRect()
> Our server received a filter which is deprecated in version 1.1.0. , so
> that we now need to be backwards compatible with version 1.0.0, or so the
> guy making our server says.
> I'll get some more detailed info from him when he gets back 16.05
> You can have a go if you like and test it:
> http://titest01.powel.no/GeminiMapServer/GeminiVADemo.wfs?service=WFS&version=1.1.0
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at mines-paris.org]
> Sent: 13. mai 2012 22:31
> Is this a server accessible from the outside so I can give a try ?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120514/05e52914/attachment-0001.html
