[gdal-dev] troubles building trunk on OSX + Xcode 4.3
jluis at ualg.pt jluis at ualg.pt
Tue May 15 19:49:02 EDT 2012
Sorry to come again with a building problem. Now on OSX 10.7.4
For forced updating reasons I was obliged to up start a chain of up
updates that ended up on upgrading to Xcode 4.3.2 and now I get these
errors linking (well, a lot more)
/System/Library/Frameworks/Carbon.framework/Carbon
is a symlink to
/System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
but than what?
Any idea how to solve this?
Thanks
Joaquim
ld: warning: path '/System/Library/Frameworks/Carbon.framework/Carbon'
following -L not a directory
Undefined symbols for architecture x86_64:
   "operator new(unsigned long)", referenced from:
       IdrisiDataset::IdrisiDataset()in IdrisiDataset.o
       _GDALRegister_IDRISI in IdrisiDataset.o
       IdrisiDataset::Open(GDALOpenInfo*)       in IdrisiDataset.o
       IdrisiRasterBand::GetDefaultRAT()       in IdrisiDataset.o
       IdrisiRasterBand::SetDefaultRAT(GDALRasterAttributeTable
const*)   in IdrisiDataset.o
       IntergraphRasterBand::IntergraphRasterBand(IntergraphDataset*,
int, int, GDALDataType)in IntergraphBand.o
       _GDALRegister_INGR in IntergraphDataset.o
This message was sent using IMP, the Internet Messaging Program.
