[gdal-dev] Policy for C/C++ API for GDAL 2.0 ?
Dmitry Baryshnikov
polimax at mail.ru
Mon May 21 03:06:42 EDT 2012
Hi Even,
20.05.2012 21:23, Even Rouault написал:
> Hi GDAL developers and users (actually, developers of other projects using
> GDAL ;-)),
> This issue was raised incidently in the "[gdal-dev] VRTComplexSource with a
> LUT, proposal" thread at http://lists.osgeo.org/pipermail/gdal-dev/2012-
> May/032872.html .
> I think it is good time to discuss now what we want to allow, or not, for GDAL
> 2.0, as far as the C/C++ API is concerned.
> C API
> Up to now, the signature of functions added in the GDAL/OGR C API has never
> changed, once they have been added.
> What should be the rule for GDAL 2.0 ?
> 1) do not change the signature of any function already present in the C API.
> If breaking changes are necessary, then introduce "FooEx", or "Foo2" versions
> of those functions as done in the past. The drawback of that approach is that
> the API becomes cluttered.
> 2) do not change the signature of any commonly used functions, but allow
> changes in marginally used functions. The definition of commonly functions
> w.r.t marginally used ones is a bit arbitrary. Looking at the symbols used by
> popular Open Source software using GDAL C API could give a clue in case of
> doubt (MapServer, QGIS, GRASS, PostGIS, or in-tree GDAL utilities using C API
> 3) allow changes even in commonly used functions.
I think that the option of three is good enough, but we must try to keep
close second option.
> Options 2) or 3) would likely require other projects to have #if GDAL_VERSION
>> = 2000 in some places if they plan to support older GDAL versions. Unless
> they plan to update their dependency requirements when they release a newer
> version of their project (Project XX version< 1.Y depends on GDAL< 2.0.
> Version>= 1.Y depends on GDAL>= 2.0).
> C++ API
> As far as the C++ API is concerned, the policy up to now was that minor
> changes between GDAL 1.X version and GDAL 1.(X+1) were OK. Generally, the
> changes have been the addition of new optional arguments, that only required
> recompilation to solve the change of ABI, but did not require code changes.
> For GDAL 2.0, I believe that most major changes could occur, especially if the
> OGR "grand unification" occurs, but for now, I don't know the impact that that
> might cause.
I think gdal 2.0 could provide new capabilities in prejudice of backward
compatibility. But it should depend of new features and their costs.
> Syntax of command line utilities
> A bit out of topic, since it is about UI and not API. But a lot of scripts in
> the wild call popular GDAL command line utilities. Changes in their syntax
> would cause potentially more headaches, given the larger number of users
> w.r.t. developers using GDAL ;-) The page at
> http://trac.osgeo.org/gdal/wiki/GDAL20Changes lists a few changes that have
> been proposed (just as a reminder : nothing listed there is officially vetted).
> The same question also arise with the API of the various bindings languages.
> Feedback welcome !
> Best regards,
> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Dmitry
