[gdal-dev] Microsoft VS 2010 - build of GDAL 1.9 does not work
James Farrell
James.Farrell at delorme.com
Mon May 21 11:37:45 EDT 2012
Oops
This company (to which I am new) keeps multiple copies of the library in multiple folders. I rather assumed we were linking against the ones in the gdal folder, but I was wrong. Needed to update the library in a different folder and it worked.
Thanks for your help
James
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Monday, May 21, 2012 11:30 AM
To: James Farrell
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Microsoft VS 2010 - build of GDAL 1.9 does not work
On 21 May 2012 16:23, James Farrell <James.Farrell at delorme.com> wrote:
> Thanks, Mateusz
> I see the source code now. I'm linking against gdal.lib.
> Shouldn't CPLStringLists's functions be in that library?
> Did I somehow build it incorrectly?
CPLStringLists is exported function.
AFAIK, it should be visible without any extra steps.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
