[gdal-dev] Microsoft VS 2010 - build of GDAL 1.9 does not work
Martin Chapman
chapmanm at pixia.com
Mon May 21 14:01:09 EDT 2012
You should be linking against gdal_i.lib.
Marty
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of James Farrell
Sent: Monday, May 21, 2012 9:23 AM
To: Mateusz Loskot
Cc: gdal-dev at lists.osgeo.org
Subject: RE: [gdal-dev] Microsoft VS 2010 - build of GDAL 1.9 does not work
Thanks, Mateusz
I see the source code now. I'm linking against gdal.lib. Shouldn't
CPLStringLists's functions be in that library? Did I somehow build it
incorrectly?
Thanks again!
James
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
Sent: Monday, May 21, 2012 11:10 AM
To: James Farrell
Subject: Re: [gdal-dev] Microsoft VS 2010 - build of GDAL 1.9 does not work
On 21 May 2012 15:41, James Farrell <James.Farrell at delorme.com> wrote:
> I cannot find a definition for Count() anywhere.
> We are not using CPLStringList in our code, but there is other code
> within GDAL that uses it. Are we supposed to make our own Count()
> function? Where is this supposed to live?
Look at port/cplstringlist.cpp
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
