[gdal-dev] ogr2ogr shapefile to mapinfo tab: no SRS.
Frans Knibbe | Geodan
frans.knibbe at geodan.nl
Thu May 24 08:42:14 EDT 2012
Hi Chaitanya,
The SRS that I am using is a projection (EPSG:28992, to be precise), so
I think geographic (unprojected) mode is not applicable. I will try to
update ticket 481.
Regards,
Frans
On 2012-05-24 13:31, Chaitanya kumar CH wrote:
> Frans,
> Add the option "-a_srs WGS84" to ogr2ogr command. It should force
> geographic mode.
> If that doesn't solve your issue, please go through the discussion on
> this topic at ticket 481.
> http://trac.osgeo.org/gdal/ticket/481
> On Thu, May 24, 2012 at 4:35 PM, Frans Knibbe | Geodan
> <frans.knibbe at geodan.nl <mailto:frans.knibbe at geodan.nl>> wrote:
> Hello,
> I wonder if someone can help me with a nasty problem with using
> ogr2ogr to convert shapefile to Mapinfo tab format. Whatever I
> try, I can not get the output to have a correct definition of the
> SRS. Ogrinfo always reports the output having a NonEarth SRS.
> The input shapefile has a *.prj file. It seems to be ignored by
> ogr2ogr. Using the -a_srs option to specify the SRS, either as an
> EPSG code or as the name of a file containing the WKT of the
> projection also fails.
> I have tested this with several versions of ogr2ogr. I do not
> notice any difference between versions. The latest version of
> ogr2ogr that I could find is "GDAL 2.0dev, released 2011/12/29".
> A web search on this subject leads to several similar problem
> descriptions, but I have not been able to find a solution or even
> a workaround.
> Regards,
> Frans
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120524/114fe949/attachment.html
