[gdal-dev] ogr2ogr shapefile to mapinfo tab: no SRS.
Frans Knibbe | Geodan
frans.knibbe at geodan.nl
Fri May 25 05:55:30 EDT 2012
Hello Luca,
Thank you for your suggestion, but it does not seem to work. I tried in
in different ways: editing the prj file of the shapefile and specifying
an alternative prj file with the a_srs option. I also tried both ESRI
WKT and OGC WKT. And I also tried 'DATUM["D_Netherlands_Bessel"' in the
ESRI WKT case, because it was 'DATUM["D_Amersfoort"' originally. In all
cases, the SRS in the output is still NonEarth.
Regards,
Frans
On 2012-05-24 19:19, Luca Sigfrido Percich wrote:
> Hi Frans,
> Il giorno gio, 24/05/2012 alle 14.42 +0200, Frans Knibbe | Geodan ha
> scritto:
>> The SRS that I am using is a projection (EPSG:28992, to be precise),
>> so I think geographic (unprojected) mode is not applicable. I will try
>> to update ticket 481.
> I checked in my c:\program files\Mapinfo\Professional\mapinfow.prj, and
> this CRS is listed as follows:
> "--- Netherlands Coordinate Systems ---"
> "Netherlands National System\p28992", 20, 109, 7, 5.387638889,
> 52.156160556, 0.9999079, 155000, 463000
> so MapInfo knows that the EPSG code 28992 is associated with it, and
> this should be matched in mitab_spatialref.cpp as
> Projection Type = 20 (SRS_PT_STEREOGRAPHIC)
> Datum = 109 (Netherlands_Bessel)
> Units = 7 (SRS_UL_METER)
> SRS_PP_CENTRAL_MERIDIAN = 5.387638889
> SRS_PP_LATITUDE_OF_ORIGIN = 52.156160556
> SRS_PP_SCALE_FACTOR = 0.9999079
> SRS_PP_FALSE_EASTING = 155000
> SRS_PP_FALSE_NORTHING = 463000
> Can you try to replace
> DATUM["Amersfoort",
> with
> DATUM["Netherlands_Bessel"
> in the prj file and see if it works?
> Sig
