[gdal-dev] Re: gdal-dev Digest, Vol 96, Issue 55
jdmorgan jdmorgan at unca.edu
Fri May 25 07:09:08 PDT 2012
This is a great listserv!
Chaitanya using a vrt worked so thank for that tip. Also, it must be the
case as Jukka says that img isn't holding the control points. But as
suggested a GeoTiff (and VRT) work fine.
Thanks so much for your help.
Cheers,
Derek
On 5/25/2012 7:25 AM, gdal-dev-request at lists.osgeo.org wrote:
> Send gdal-dev mailing list submissions to
> 	gdal-dev at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/mailman/listinfo/gdal-dev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	gdal-dev-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of gdal-dev digest..."
> Today's Topics:
>     1. Re: georeference and project a jpeg (Chaitanya kumar CH)
>     2. Re: georeference and project a jpeg (Jukka Rahkonen)
>     3. Re: ogr2ogr shapefile to mapinfo tab: no SRS.
>        (Frans Knibbe | Geodan)
>     4. Re: ogr2ogr shapefile to mapinfo tab: no SRS.
>        (Luca Sigfrido Percich)
>     5. Re: ogr2ogr shapefile to mapinfo tab: no SRS.
>     6. Re: ogr2ogr shapefile to mapinfo tab: no SRS.
> Message: 1
> Date: Fri, 25 May 2012 12:30:56 +0530
> From: Chaitanya kumar CH<chaitanya.ch at gmail.com>
> Subject: Re: [gdal-dev] georeference and project a jpeg
> To: jdmorgan<jdmorgan at unca.edu>
> Cc: gdal-dev at lists.osgeo.org
> Message-ID:
> 	<CAMKgpObbfjDbRUQCdq=nARfp8L8vRniY9G13K4t0m8K2Ldgw6A at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Derek,
> Please provide the gdalinfo output of the img file.
> Also, try this:
> Create a vrt file instead of a HFA using the same gdal_translate command.
> See if gdalwarp works with the vrt file.
> On Fri, May 25, 2012 at 7:17 AM, jdmorgan<jdmorgan at unca.edu>  wrote:
>>   Hello,
>> I am attempting to georeference and project a jpeg image using only gdal
>> tool.  I have georeferenced the jpeg using the following command:
>> gdal_translate -a_srs EPSG:102719 -of HFA -gcp 0.0 0.0 -82.5586187839508
>> 35.59414007259327 -gcp 0.0 410.0 -82.55858659744263 35.5937998255945 -gcp
>> 520.0 0.0 -82.55741715431213 35.594340730401775 -gcp 520.0 410.0
>> -82.55728840827942 35.5940266570877 NCDCLogo.jpg NCDCLogo.img  ****
>> The command run fine and produces a img file however it does not line up
>> with similarly project layer per the gcp’s.  When I check the projection
>> information the file shows to be unprojected. Further, when I attempt to
>> project the resulting raster with gdalwarp I get the following errors:
>> “There is no affine transformation and no GCPs.”
>> Any pointers here would be greatly appreciated.
>> Thanks,
>> Derek
Derek @ NEMAC
http://nemac.unca.edu
