[gdal-dev] __main__.gdal_config_error when trying to install gdal
Chao YUE
chaoyuejoy at gmail.com
Sun May 27 13:58:55 PDT 2012
Thanks Etienne, then I guess I will have the problem of python version? I
guess I will need a virtual python environment (or something) if I need
python 3 for newer versions?
best,
Chao
2012/5/27 Etienne Tourigny <etourigny.dev at gmail.com>
> Hi chao
> you should install gdal using the ubuntugis (stable or unstable)
> repository . 1.6.3 is really old, plus you shouldn't install the
> debian packages on ubuntu.
> see:
> https://launchpad.net/~ubuntugis
> http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries
> If you really have to build it see:
> http://trac.osgeo.org/gdal/wiki/BuildHints
> Etienne
> On Sun, May 27, 2012 at 5:39 PM, Chao YUE <chaoyuejoy at gmail.com> wrote:
> > Finally I managed to install gdal 1.6.3 using a debien package (and I
> have
> > to install libgdal1-1.6.0 before ). But I read from
> > http://trac.osgeo.org/gdal/wiki/GdalOgrInPython
> > saying that from version 1.7.0, python 3 is needed.
> > thanks et cheers,
> > Chao
> > 2012/5/27 Chao YUE <chaoyuejoy at gmail.com>
> >> Dear all,
> >> I am new to gdal and when I try to install it on my ubuntu computer, I
> >> have the following error. It occurs either with pip or with manual
> python
> >> setup.py build.
> >> could anyone give me some clue on this problem? thanks in advance.
> >> Chao
> >> chaoyue at chaoyue-Aspire-4750:~/python/python_lib/build/gdal$ sudo python
> >> setup.py install
> >> [sudo] password for chaoyue:
> >> running install
> >> Checking .pth file support in /usr/local/lib/python2.7/dist-packages/
> >> /usr/bin/python -E -c pass
> >> TEST PASSED: /usr/local/lib/python2.7/dist-packages/ appears to support
> >> .pth files
> >> running bdist_egg
> >> running egg_info
> >> writing GDAL.egg-info/PKG-INFO
> >> writing top-level names to GDAL.egg-info/top_level.txt
> >> writing dependency_links to GDAL.egg-info/dependency_links.txt
> >> Traceback (most recent call last):
> >> File "setup.py", line 267, in <module>
> >> ext_modules = ext_modules )
> >> File "/usr/lib/python2.7/distutils/core.py", line 152, in setup
> >> dist.run_commands()
> >> File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands
> >> self.run_command(cmd)
> >> File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command
> >> cmd_obj.run()
> >> File "/usr/lib/python2.7/dist-packages/setuptools/command/install.py",
> >> line 73, in run
> >> self.do_egg_install()
> >> line 93, in do_egg_install
> >> self.run_command('bdist_egg')
> >> File "/usr/lib/python2.7/distutils/cmd.py", line 326, in run_command
> >> self.distribution.run_command(command)
> >> cmd_obj.run()
> >> File
> "/usr/lib/python2.7/dist-packages/setuptools/command/bdist_egg.py",
> >> line 172, in run
> >> self.run_command("egg_info")
> >> cmd_obj.run()
> >> File
> "/usr/lib/python2.7/dist-packages/setuptools/command/egg_info.py",
> >> line 179, in run
> >> self.find_sources()
> >> File
> >> line 254, in find_sources
> >> mm.run()
> >> File
> >> line 308, in run
> >> self.add_defaults()
> >> File
> >> line 332, in add_defaults
> >> sdist.add_defaults(self)
> >> File "/usr/lib/python2.7/dist-packages/setuptools/command/sdist.py",
> >> line 191, in add_defaults
> >> build_ext = self.get_finalized_command('build_ext')
> >> File "/usr/lib/python2.7/distutils/cmd.py", line 312, in
> >> cmd_obj.ensure_finalized()
> >> File "/usr/lib/python2.7/distutils/cmd.py", line 109, in
> >> ensure_finalized
> >> self.finalize_options()
> >> File "setup.py", line 164, in finalize_options
> >> self.gdaldir = self.get_gdal_config('prefix')
> >> File "setup.py", line 144, in get_gdal_config
> >> return fetch_config(option)
> >> File "setup.py", line 97, in fetch_config
> >> raise gdal_config_error, e""")
> >> File "<string>", line 4, in <module>
> >> __main__.gdal_config_error: [Errno 2] No such file or directory
> >> Chao YUE
> >> Laboratoire des Sciences du Climat et de l'Environnement (LSCE-IPSL)
> >> UMR 1572 CEA-CNRS-UVSQ
> >> Batiment 712 - Pe 119
> >> 91191 GIF Sur YVETTE Cedex
> >> Tel: (33) 01 69 08 29 02; Fax:01.69.08.77.16
> > Chao YUE
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
Chao YUE
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120527/077d665d/attachment.html>
