[gdal-dev] gdal opencl support
Even Rouault
even.rouault at mines-paris.org
Mon May 28 06:49:36 PDT 2012
Selon Yogesh Dahiya <yogesh at vizexperts.com>:
> Does gdal uses opencl for different resampling algorithms.
> If yes how can it be configured to use opencl?
The warping algorithms (as in gdalwarp) can use opencl acceleration provided
that you build GDAL with support for it. Currently, the build support is only
done for Unix (see the --with-opencl option of configure). For Windows, you
would have to hack in nmake.opt and alg/makefile.vc
> Thanks
