[gdal-dev] GDAL with mdb support on Ubuntu 12.04
Luca Casagrande
luca.casagrande at gmail.com
Mon May 28 06:50:51 PDT 2012
Il 28/05/2012 15:41, Even Rouault ha scritto:
>> Hire is the full config.log:
>> http://ubuntuone.com/3HlRqtTs0nu4NeguX2eIG4
> I have had a look at this config.log and found that in the step where the
> configure script tries to check the libjvm, a non-expected string "missing" is
> placed on the gcc line, causing it to fail. I don't know where this comes from,
> but perhaps from something that happened in a previous step. So I'd recommand
> you to just "./configure --with-java --with-mdb" and drop other configure
> options. If it works, you can try to reincorporate them progressively to find
> the single one that cause the jvm detection step to fail.
Bingo! :)
If I remove just --with-freexl=/usr/local all is fine and there is no
configure error.
Thank you very much!
L.
Luca Casagrande
http://www.lucacasagrande.net
