[gdal-dev] ogr ODBC problem
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Thu May 31 06:48:56 PDT 2012
Thanks Jeff
I got now OGR_ODBC: Table ?s???s!.????????? has no identified FID column.
I found that several users had this problem but found no solution. I don't
have write access to this MSSQL server.
I'm connecting via ODBC to a non spatial table, but it contains latitude
and longitude information. I will use it to define a OGRVRTDataSource and
create geometry from point.
Any clue on what I can do?
thanks
steve
Jeff McKenna <jmckenna at gatewaygeomatics.com>@lists.osgeo.org
Envoyé par : gdal-dev-bounces at lists.osgeo.org
2012-05-30 17:06
A
gdal-dev at lists.osgeo.org
cc
Objet
Re: [gdal-dev] ogr ODBC problem
On 12-05-30 5:09 PM, Steve.Toutant at inspq.qc.ca wrote:
> Hi!
> I use this command to get the tables from an ODBC connection
> ogrinfo ODBC:User/Pwd at DNS
> The connection is succesful but I get this error several times
> ERROR 1: No column definitions found for table '?s???s!.???????????',
> layer not usable.
> I used OGR ODBC for several months from a Windows server to a MSSQL
server
> Now I'm migrating to linux and accessing the same MSSQL SERVER and I get
> this error.
> Note that if I connect with isql, I can connect and query the database
> without problem.
> So the problem really seems to be with OGR
> What can cause this No column definitions found for table error
> And why the table name looks like this  '?s???s!.???????????',
Hi Steve,
I was just debugging an ogrinfo command for MS4W/Oracle, and was
reminded of the trick to show more debug info at the commandline:
   set CPL_DEBUG=on
I'm going to keep that one in my back pocket from now on.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120531/ce33648b/attachment-0001.html>
