[gdal-dev] RE [Polluriel potentiel] Re: ogr ODBC problem [SOLVED]
Steve.Toutant at inspq.qc.ca
Thu May 31 11:14:24 PDT 2012
for ogrinfo we were using, as explained here,
http://mapserver.org/input/vector/VirtualSpatialData.html#steps-for-display
ogrinfo ODBC:User/Pwd at mssql__archives msStatut_station2002_2006
That was working on windows
Though, That doesn't work on our linux distro linux sles 11 sp1. It as to
be (comma instead of space)
ogrinfo ODBC:User/Pwd at mssql__archives,msStatut_station2002_2006
But, For some reasons, this still doesn't work to get the list of tables
on our linux distro
But it is useless in my case.
Also, our virtual data file looks like this on windows
<OGRVRTDataSource>
<OGRVRTLayer name="stations">
<SrcDataSource>ODBC:User/Pwd at mssql__archives</SrcDataSource>
<SrcLayer>dbo.msStatut_station2002_2006</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding="PointFromColumns" x="Longitude"
y="Latitude"/>
</OGRVRTLayer>
</OGRVRTDataSource>
That is working on windows
For our distro linux We need to add the table name
<SrcDataSource>ODBC:User/Pwd at mssql__archives,msStatut_station2002_2006</SrcDataSource>
Perhaps it is not a windows vs linux issue but an OGR version issue.
Thanks for your help
Steve
Brent Fraser <bfraser at geoanalytic.com>
2012-05-31 10:49
A
cc
gdal-dev at lists.osgeo.org
Objet
[Polluriel potentiel] Re: [gdal-dev] ogr ODBC problem
Steve,
Here's a snippet from a MapServer map file I used to access a
non-spatial MS SQL server via OGR+VRT+ODBC:
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "<OGRVRTDataSource>
<OGRVRTLayer name='v_MyPoints'>
<SrcDataSource>ODBC:username/password at WebMapDSN,v_MyPoints</SrcDataSource>
<SrcSQL>
SELECT * FROM v_MyPoints
WHERE PropertyID=%PropertyID%
</SrcSQL>
<FID>PointID</FID>
<GeometryField encoding='PointFromColumns' y='SurfaceLatitude'
x='SurfaceLongitude'/>
<LayerSRS>NAD83</LayerSRS>
</OGRVRTLayer>
</OGRVRTDataSource>"
PROCESSING "CLOSE_CONNECTION=DEFER"
DATA "v_MyPoints"
In my case I was able to use the view's primary key as the FID. Hope this
helps...
Best Regards,
Brent Fraser
On 5/31/2012 7:48 AM, Steve.Toutant at inspq.qc.ca wrote:
Thanks Jeff
I got now OGR_ODBC: Table ?s???s!.????????? has no identified FID column.
I found that several users had this problem but found no solution. I don't
have write access to this MSSQL server.
I'm connecting via ODBC to a non spatial table, but it contains latitude
and longitude information. I will use it to define a OGRVRTDataSource and
create geometry from point.
Any clue on what I can do?
thanks
steve
Jeff McKenna <jmckenna at gatewaygeomatics.com>@lists.osgeo.org
Envoyé par : gdal-dev-bounces at lists.osgeo.org
2012-05-30 17:06
A
cc
Objet
On 12-05-30 5:09 PM, Steve.Toutant at inspq.qc.ca wrote:
> Hi!
> I use this command to get the tables from an ODBC connection
> ogrinfo ODBC:User/Pwd at DNS
> The connection is succesful but I get this error several times
> ERROR 1: No column definitions found for table '?s???s!.???????????',
> layer not usable.
> I used OGR ODBC for several months from a Windows server to a MSSQL
server
> Now I'm migrating to linux and accessing the same MSSQL SERVER and I get
> this error.
> Note that if I connect with isql, I can connect and query the database
> without problem.
> So the problem really seems to be with OGR
> What can cause this No column definitions found for table error
> And why the table name looks like this '?s???s!.???????????',
Hi Steve,
I was just debugging an ogrinfo command for MS4W/Oracle, and was
reminded of the trick to show more debug info at the commandline:
set CPL_DEBUG=on
I'm going to keep that one in my back pocket from now on.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120531/e8e48d83/attachment-0001.html>
