[gdal-dev] GDALGetMaskFlags() bug with GTOPO30 data
Craig Bruce csbruce at cubewerx.com
Thu May 31 11:41:14 PDT 2012
I have run into a bug using GDALGetMaskFlags() with GTOPO30 data with
the GDAL 1.9.0 C API.  The test data includes a NoData value:
[dev:~] gdalinfo /cw/testdata/gtopo30/w180s60.dem
Driver: EHdr/ESRI .hdr Labelled
Band 1 Block=7200x1 Type=Int16, ColorInterp=Undefined
  NoData Value=-9999
When I call GDALGetMaskFlags(), I get back 0x01 which corresponds to
GMF_ALL_VALID, meaning that the image is fully opaque.  I was hoping to
discard the mask band in such a case as an optimization to avoid reading
mask samples.  However, it appears that the GDALGetMaskFlags() is returing
GMF_ALL_VALID by mistake and should be returning GMF_NODATA (0x08) instead.
If I use the mask returned from GDALGetMaskBand(), it gives me the proper,
variable mask values, so the bug is in falsely reporting the type of the
mask band.
Dr. Craig S. Bruce        | Ph 819-771-8303 x205 |             CubeWerx Inc.
Senior Software Developer |   Fax 819-771-8388   |  Gatineau, Québec, Canada
csbruce at cubewerx.com      |  http://csbruce.com/ |  http://www.cubewerx.com/
     "How many legs does a dog have if you call the tail a leg?  Four.
      Calling a tail a leg doesn't make it a leg." -- Abraham Lincoln
