[gdal-dev] Reading image byte data into a dataset in C#
avtoader
avtoader at gmail.com
Thu May 31 18:09:16 PDT 2012
How does an individual with TIFF data (byte array) load it into a GDAL
dataset? I'm trying to eliminate writes to disk to save on time so assuming
memory is not an issue, how do I accomplish this?
Thanks in advance!
-Alex
View this message in context: http://osgeo-org.1560.n6.nabble.com/Reading-image-byte-data-into-a-dataset-in-C-tp4978429.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
