[gdal-dev] DGN File with 10 layers recognized in OGR only 1 layer + DGN to SVG converter
Miro Karpis
miroslav.karpis at gmail.com
Fri Nov 2 01:33:56 PDT 2012
Thanks for the info Frank.So if I understand it correctly than class
OGRFeature should have one method that should give me value of attribute
called 'LAYER' (or similar). Please what is the method called - I can not
see it in the documentation?
thanks again.
On Thu, Nov 1, 2012 at 11:18 PM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> On Thu, Nov 1, 2012 at 3:11 PM, Miroslav Karpis <miroslav.karpis at gmail.com
> > wrote:
>> Hi, please can you help me with following:
>> 1) When I open DGN file which has for example 10 layers,
>> OGRDataSource::GetLayerCont () returns 1. What can be the problem? The
>> documentation says that OGR DGN is supporting layers.
> Miroslav,
> DGN layers are represented as an attribute in the features of the single
> OGR layer. I think the attribute is called LAYER.
> Because of the way the dgn file is structured it would be hard to
> represent the DGN layers as OGR layers efficiently. Also, since all
> features have the same schema there was relatively little value in keeping
> them as distinct layers.
>> 2) Does anybody know about an example of conversion from DGN to SVG?
> I think MapServer has some sort of SVG support and given that MapServer
> has at least some degree of "autostyling" available from OGR DGN it might
> capture some of the look and feel of the original DGN.
> I doubt this is a well trod route.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121102/034e466d/attachment.html>
