[gdal-dev] Ogr and Dwg via Teigha (in C#)
Noon Silk
noonslists+gdal at gmail.com
Sat Nov 3 00:32:32 PDT 2012
So, further to this, I've not had much luck with my previous
approach. I'm going to now try this method; but I kind of want to
understand why what I tried didn't work.
What I mean by "Didn't work" is that my requests to open DWG files,
or just grab an instance of the DWG driver, didn't work.
I ask for an instance like so (in C#):
Ogr.RegisterAll();
Driver d = Ogr.GetDriverByName("DWG");
"d" comes back as null. So, I expected it to return something given
that I thought I was correctly "enablding" the DWG library. But, I
also checked to see if the number of available drivers changed, after
me doing what I would've expected to result in the enablding. Sadly,
it didn't. So I can only assume that I didn't enanble it correctly.
So, my process for enabling the DWG driver was basically to allow it
to be compiled as part of the "gdal\ogr\ogrsf_frmts\makefile.vc" (by
adding in the directory and the obj files). I also set up the required
Teigha libraries by uncommenting and correctly setting the particular
bits of nmake.opt.
Then the only other change I made was to generate the SWIG bindings.
Is this the correct way to enable the dwg bindings? Is there
something obvious I've missed? Would linking this other -dev build
script with the particular source work better?
Thanks,
Noon
On Fri, Nov 2, 2012 at 9:30 AM, Noon Silk <noonslists+gdal at gmail.com> wrote:
> On Mon, Oct 29, 2012 at 11:34 PM, Tamas Szekeres <szekerest at gmail.com> wrote:
>> You might also take a look at the -dev packages at
>> http://www.gisinternals.com/sdk/
>> The compilation is controlled by a single makefile, so you can use:
>> nmake gdal
>> nmake gdal-csharp
> Thanks; I happened to grab the "MSVC2005 (Win64) -development", which
> doesn't have that ..., I'll give this a go.
>> to achieve the desired result.
>> Best regards,
>> Tamas
> Noon
