[gdal-dev] problem with compiling grass with gdal
Even Rouault
even.rouault at mines-paris.org
Sat Nov 3 04:30:38 PDT 2012
Selon Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2012/10/24 Martin Landa <landa.martin at gmail.com>:
> >> Perhaps try to diff the output of ldd libgdal.so ??
> > Apparently libstdc++.so.6 is missing in trunk.
> seems to be solved.
> $ gdal-config --version
> 2.0.0
> $ ldd /usr/local/lib/libgdal.so | grep 'c++'
> libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6
> (0x00007ff1b00c6000)
Yes, I think that the recent commit in
http://trac.osgeo.org/gdal/changeset/25195 fixed the issue.
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
