[gdal-dev] Fwd: OSRExportToProj4 losing datum
Even Rouault
even.rouault at mines-paris.org
Sat Nov 3 06:04:32 PDT 2012
Selon Roger Bivand <Roger.Bivand at nhh.no>:
> >> Even,
> >> I've opened #4880 on this - it is problematic in the R-spatial setting
> >> because the CRS (coordinate reference system) object recorded in each
> >> Spatial object uses the PROJ.4 string to represent spatial reference. A
> user
> >> can create a CRS, write out a raster (which expands the description to
> >> include , read it back, and the CRS are not the same. The same does not
> >> appear to happen with OGR write/read (ESRI Shapefile driver). Is the
> >> conclusion that calling programs must first find "NAD83" in the raster
> input
> >> WKT, if it is there set the environment variable if the default GDAL
> >> behaviour is not desired, export to Proj4, then remove the environment
> >> variable if set? Does this only affect NAD83 - it does seem to be limited
> to
> >> this datum, as WGS84 does not show the same behaviour.
> > Roger,
> > Hum, I somehow regret of having tried to fix the issue that was originally
> > raised in trac.osgeo.org/gdal/ticket/3450 since it seems that all GRASS and
> now
> > RGdal developers hate me now ;-) But hopefully they will realize that they
> > should consider using more reliable ways of representing SRS.
> > In the case of NAD83, +datum=nad83 is expanded as
> > GEOGCS[\"NAD83\",DATUM[\"North_American_Datum_1983\",SPHEROID[\"GRS
1980\",6378137,298.257222101,AUTHORITY[\"EPSG\",\"7019\"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY[\"EPSG\",\"6269\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.0174532925199433,AUTHORITY[\"EPSG\",\"9108\"]],AUTHORITY[\"EPSG\",\"4269\"]]
> > . This expansion is done at import time (importFromProj4).
> > This explains why at export time the +datum isn't exported since there's a
> > TOWGS84 node.
> > You would also have a similar behaviour with +datum=WGS72 since
> +datum=WGS72
> > expansion implicitely adds a TOWGS84 node.
> > In the case of NAD83, I'm not sure why SetWellKnownGeogCS("NAD83") adds the
> > TOWGS84[0,0,0,0,0,0,0]. If this was removed, then I believe that
> exportToProj4()
> > would again generate +datum=nad83. But I'm now more than hesitant in
> touching
> > anything in that area, since this could potentially break something else.
> > Sorry to repeat myself, but you should NOT use proj4 strings as a way of
> > representing a SRS. It is just not reliable. It is not, and has never been.
> You
> > must realize that proj4 only knows 10 datum names (see pj_datums.c). All
> other
> > datums must be translated into +ellps= +towgs84= anyway. You shouldn't
> assume
> > that round-tripping importFromProj4() / exportToProj4() will be perfect.
> proj4
> > strings are only usefull for proj4, to do SRS transformations. They are not
> > meant at being a comprehensive way of representing SRS. I'm not sure how
> hard it
> > is for RGdal, but you should consider migrating to using WKT strings /
> model.
> > WKT has been designed for that.
> Thanks, Even.
> It isn't easy to make design decisions, and in the case of sp, the R
> spatial class definition package, our concern was that spatial data
> analysts were most often unaware of spatial reference issues. PROJ.4
> strings are a low-threshold text string entry point for users who have no
> grasp of other representations, and when we began (2003), were among the
> only games in town. Inside R, the objects cannot reliably be pointers to
> C/C++ objects cross-platform; indeed, it is only a few month since we
> achieved PROJ.4/GDAL CRAN (archive network) support for OSX on two intel
> architectures. I'll try out adding a user-settable argument in calling
> functions to set and unset the environment variable, but this isn't very
> satisfactory.
If you were happy with GDAL < 1.8 behaviour, you could also always set
OVERRIDE_PROJ_DATUM_WITH_TOWGS84=NO before calling ExportToProj4(). Only the
cases where a TOWGS84 node is defined in the OGRSpatialReference object that
contradicts the default +towgs84 hard-coded in the datum definition in PROJ.4
pj_datums.c would be affected, but that's probably a minor use case.
> I agree that in a better world, in sp 2.0, we should replace the
> representation in the CRS class with (maybe) WKT. But I don't think that
> this will happen any time soon, and in any case, we would still need to be
> able to let users to enter the simpler PROJ.4 representations, as writing
> WKT is much more error-prone.
Using EPSG codes can also be a convenient way for users to specify a SRS, but it
does not cover all possible SRS.
> Best wishes,
> Roger
> > Best regards,
> > Even
> Roger Bivand
> Department of Economics, NHH Norwegian School of Economics,
> Helleveien 30, N-5045 Bergen, Norway.
> voice: +47 55 95 93 55; fax +47 55 95 95 43
> e-mail: Roger.Bivand at nhh.no
