[gdal-dev] Is there any way of accesing the GDAL utilities from C#?
Tamas Szekeres
szekerest at gmail.com
Wed Nov 7 01:40:47 PST 2012
With regards to the C# bindings Gdal.FillNodata should work, but
Gdal.RasterizeLayer requires some adjustments. You might file a ticket for
this at http://trac.osgeo.org/gdal/newticket
Best regards,
Tamas
2012/11/7 Dev3 <devdatta at tengshe.in>
> Hi All!
> I am trying to do some data processing in my .NET application. I have found
> that my work is done by using just two of the gdal utilities:
> gdal_rasterize
> & gdal_fillnodata.
> However, when I downloaded the C# bindings, I realized that the utilities
> are not part of it. Is there any quick way of getting the utilities from
> C#,
> or will it be quicker to just use System.Diagnostics.Process.Start()
> method,
> to run the gdal Utilities on the command line?
> http://osgeo-org.1560.n6.nabble.com/Is-there-any-way-of-accesing-the-GDAL-utilities-from-C-tp5014441.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121107/ac7f9964/attachment.html>
