[gdal-dev] gdalinfo on PostGIS rasters (GDAL 1.9)
Mathieu Basille basille at ase-research.org
Thu Nov 8 05:57:08 PST 2012
Dear James and Even,
Thank you for you fast answers!
James, I do have the raster properly referenced (at least from what I
understand). For example:
mydb=# SELECT st_georeference(rast) FROM myraster WHERE rid=1;
  st_georeference
  0.1670000000   +
  0.0000000000   +
  0.0000000000   +
  -0.1670000000  +
  -180.0000000000+
  83.6185000000  +
(1 line)
mydb=# SELECT st_georeference(rast) FROM myraster WHERE rid=100;
  st_georeference
  0.1670000000   +
  0.0000000000   +
  0.0000000000   +
  -0.1670000000  +
  -129.9000000000+
  79.4435000000  +
(1 line)
Even, that's what I was afraid of... I think I will give it a try. Is there
a preferred solution between sources from Subversion and the nightly
snapshots?
Second, do I understand it correctly that I need to 1) install GDAL from
sources, and 2) recompile PostGIS on this GDAL version?
Third, can GDAL trunk live together with my current version of GDAL?
Thanks a lot for your help,
Mathieu.
Le 07/11/2012 18:03, Even Rouault a écrit :
>> Detailed set-up:
>> * PostGIS 2.1.0SVN (r10597)
>> * GDAL 1.9.0, released 2011/12/29
>> * OS: Debian Wheezy
> There have been significant fixes done in the PostGISRaster driver in GDAL trunk
> a few weeks ago. You might want to try it.
~$ whoami
Mathieu Basille, PhD
~$ locate --details
University of Florida \\
Fort Lauderdale Research and Education Center
(+1) 954-577-6314
http://ase-research.org/basille
~$ fortune
« Le tout est de tout dire, et je manque de mots
Et je manque de temps, et je manque d'audace. »
  -- Paul Éluard
