[gdal-dev] Suggestion for API addition
David Strip
gdal at stripfamily.net
Sun Nov 11 08:17:17 PST 2012
On 11/11/2012 3:53 AM, Even Rouault wrote:
> Le dimanche 11 novembre 2012 03:45:57, David Strip a écrit :
>> The current GDALRasterBand::RasterIO signature makes it easy to read or
>> write a contiguous subregion of the band. However, if you want to read or
>> write the entire band into/from a contiguous sub-region of the buffer,
>> it's not nearly as straightforward. You can do this by using the
>> nLineSpace parameter, giving the size of the subregion for buffer size
>> parameters, and offsetting the address of the buffer. It works, but that
>> makes the code a bit baroque and hard to read.
>> How about a signature that indicates the entire band will be read, but
>> moves the meaning of the offset to the buffer. Something like
>> CPLErr GDALRasterBand::RasterIO ( GDALRWFlag eRWFlag,
>> int nXSize,
>> int nYSize,
>> void * pData,
>> int nBufXOff,
>> int nBufYOff,
>> int nBufXSize,
>> int nBufYSize,
>> GDALDataType eBufType,
>> int nPixelSpace,
>> int nLineSpace )
>> Obviously I can write a wrapper for this functionality that just calls
>> RasterIO, setting the appropriate values for buffer size, etc, but I was
>> thinking I might not be the only one who wants to crop a buffer while
>> writing to the band, or reading a band into a sub-region of a buffer.
> This is just a personal opinion, but I'm not convinced this is a good idea. I
> think people will be more confused than currently. The meaning of the
> parameters of the existing RasterIO() requires some time to be confortable
> with, but once you've finished learning curve, it is pretty logical. Adding
> another method with the same name, almost same parameters, but subtle
> differences in behaviour is not going to make users life easier.
You're right that the actual signature and function name I provided
would not be the right way to go. The substance of my question was
whether there would be value to a function which crops a buffer while
writing to the band. Rather than overloading RasterIO, the name could be
writeCroppedBand or something.
> Why not adding an example code snippet of your use case in the documentation
> of the current API ? (if I've understood well, your proposal is just a
> convenient way of computing the right value for pData, likely pData =
> pBufferBase + nBufYOff * nLineSpace + nBufXOff * nPixelSpace)
The value of a new function is code clarity. It's not just computing
pData, it's that the nBufXSize and nBufYSize become the size of the
cropped region, not the size of the actual buffer, and offsets are not
visible in the existing signature (there is no nBufXOff, nBufYOff),
they're buried in the computation of pData, which of course no longer
points to the actual buffer. When the existing function is used for this
purpose it becomes very difficult to see what is actually happening. Of
course one can say that's what comments are for.
> Furthermore, if you want to operate on the whole band, you should also remove
> the nXSize and nYSize parameters that are useless.
Yes, those should have been removed
>> This cropping interpretation doesn't allow for decimation/replication. It
>> requires the buffer size be large enough to copy the entire band into the
>> sub-region of the buffer. Allowing for decimation/replication would
>> require yet more parameters.
> Not sure to understand that. The presence of nBufXSize, nBufYsize in your
> proposal allows subsampling/oversampling. Perhaps you meant something else
> with decimation/replication ?
You're right. nPixelSpace and nLineSpace now become required, no
default values will work.
