[gdal-dev] Suggestion for API addition
Even Rouault even.rouault at mines-paris.org
Sun Nov 11 11:56:38 PST 2012
> GDALRasterBand::WriteCropToBand(int nCropSizeX, // width of the cropped
> region int nCropSizeY, // height of the cropped region int nXOffset,   //
> offset to the left edge of the cropped region int nYOffset,   // offset to
> the top of the cropped region void * pBuf,    // pointer to the buffer
> (uncropped) GDALDataType eBufType, // data type in the buffer int
> nPixelSpace, // byte offset from one pixel to the next int nLineSpace)  //
> byte offset from one line to the next {
>    void * pData = pBuf + nYOffset * nLineSpace + nXOffset * nPixelSpace;
>    this->RasterIO(GF_Write, 0, 0, this->nRasterXSize, this->nRasterYSize,
>                   pData, nCropSizeX, nCropSizeY, eBuftype, nPixelSpace,
> nLineSpace); }
>  The code is obviously not very complicated. The value is that when you're
> reading code you can tell immediately that what's happening is the buffer
> is being cropped and written. If written directly in terms of RasterIO the
> intent is buried in the computation of the parameters, making it less
> clear.
Your implementation is more about rescaling than cropping (
http://en.wikipedia.org/wiki/Cropping_%28image%29 ). For me cropping implies
at least working with a subwindow of the original image.
Sorry, but I still think this is going to confuse people more than help them.
