[gdal-dev] Suggestion for API addition
Even Rouault even.rouault at mines-paris.org
Sun Nov 11 12:36:50 PST 2012
> now it's my turn to be confused.
> This is pixel-by-pixel copy of a subset of the input pixels. It is a
> subwindow of the original image, exactly as you say.
> I'm taking an m x n input image and copying p x q pixels (p <= m, q <=n)
> into p x q pixels in the band. The scale is unchanged.
Ah indeed, if you consider the point of view of the buffer, not the GDAL
raster, that makes some sense...
Honestly I'm still not convinced. I let your proposal to other GDAL developers
that might be interested.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
