[gdal-dev] No Spatial Reference System from UTM Ozi .map file
Nik Sands
nixanz at nixanz.com
Sun Nov 11 20:02:59 PST 2012
I have two sets of Ozi .map files (and corresponding ozf2 files) that behave very differently when processed by GDAL using the following code:
char *srcWKT = (char *)GDALGetProjectionRef( hSrcDS );
if ( srcWKT == NULL || strlen(srcWKT) <= 0 )
return NO;
printf("srcWKT:\n\n%s\n\n", srcWKT);
OGRSpatialReferenceH srcSRS = OSRNewSpatialReference(srcWKT);
if ( ! srcSRS )
printf("FAILED TO GET SOURCE SPATIAL REFERENCE SYSTEM.\n");
The first set of .map files work fine, producing output such as this:
srcWKT:
PROJCS["unnamed",GEOGCS["AGD66",DATUM["Australian_Geodetic_Datum_1966",SPHEROID["Australian National Spheroid",6378160,298.25,AUTHORITY["EPSG","7003"]],TOWGS84[-117.808,-51.536,137.784,0.303,0.446,0.234,-0.29],AUTHORITY["EPSG","6202"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4202"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",147],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",10000000],UNIT["Meter",1]]
However, for the second set I cannot get a spatial reference system and I get this output:
srcWKT:
LOCAL_CS[""Ozi" projection "(UTM) Universal Transverse Mercator"",UNIT["Meter",1]]
Please help me figure out why the two sets of .map files behave so differently. In particular, how can I get a spatial reference system for the failing .map files?
(Content of two example files are below. First one is OK, second one fails. Let me know if I can provide any further information.)
Thanks in anticipation,
Nik.
OK:
OziExplorer Map Data File Version 2.2
R2257
D:\GPS and Mapping\OziExplorer\Maps\Tassie 25k\R2257.ozf2
1 ,Map Code,
Australian Geodetic 1966,, 0.0000, 0.0000,WGS 84
Reserved 1
Reserved 2
Magnetic Variation,,,E
Map Projection,Transverse Mercator,PolyCal,No,AutoCalOnly,No,BSBUseWPX,No
Point01,xy, 0, 0,in, deg, , ,, , ,, grid, ,220000.77942328,5579999.7247315,
Point02,xy, 1, 0,in, deg, , ,, , ,, grid, ,220004.03889463,5579999.7247315,
Point03,xy, 0, 1,in, deg, , ,, , ,, grid, ,220000.77942328,5579996.4652601,
Point04,xy, 1, 1,in, deg, , ,, , ,, grid, ,220004.03889463,5579996.4652601,
Point05,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point06,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point07,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point08,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point09,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point10,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point11,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point12,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point13,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point14,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point15,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point16,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point17,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point18,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point19,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point20,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point21,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point22,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point23,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point24,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point25,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point26,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point27,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point28,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point29,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point30,xy, , ,in, deg, , ,, , ,, grid, , , ,
Projection Setup, 0.000000000, 147.000000000, 0.999600000, 500000.00, 10000000.00,,,,,
Map Feature = MF ; Map Comment = MC These follow if they exist
Track File = TF These follow if they exist
Moving Map Parameters = MM? These follow if they exist
MM0,Yes
MMPNUM,4
MMPXY,1,0,0
MMPXY,2,6137,0
MMPXY,3,6137,3069
MMPXY,4,0,3069
MMPLL,1, 143.725652, -39.883721
MMPLL,2, 143.959253, -39.890076
MMPLL,3, 143.955249, -39.980236
MMPLL,4, 143.721343, -39.973861
MM1B,3.251186
MOP,Map Open Position,0,0
IWH,Map Image Width/Height,6137,3069
FAILS:
r2256.jgw
D:\Documents and Settings\nelsonp\My Documents\General Admin\Personal\Tasmania 1 to 25,000\North West OZF2\r2256.ozf2
1 ,Map Code,
Australian Geodetic 1966,WGS 84, 0.0000, 0.0000,WGS 84
Reserved 1
Reserved 2
Map Projection,(UTM) Universal Transverse Mercator,PolyCal,No,AutoCalOnly,No,BSBUseWPX,No
Point01,xy, 0, 0,in, deg, , ,, , ,, grid, 55,219999.09067205,5570000.7412442,S
Point02,xy, 1000, 1000,in, deg, , ,, , ,, grid, 55,223259.16350298,5566740.6684133,S
Point03,xy, , ,in, deg, , ,, , ,, grid, , , ,
Point04,xy, , ,in, deg, , ,, , ,, grid, , , ,
Projection Setup, 0.000000000, -120.000000000, 0.999600000, 0.00, -4000000.00, 34.000000000, 40.500000000,,,
MM0,Yes
MMPNUM,4
MMPXY,1,0,0
MMPXY,2,6136,0
MMPXY,3,6136,3069
MMPXY,4,0,3069
MMPLL,1, 143.721340, -39.973660
MMPLL,2, 143.955261, -39.980047
MMPLL,3, 143.951253, -40.070068
MMPLL,4, 143.717025, -40.063661
MM1B,3.251882
IWH,Map Image Width/Height,6136,3069
