[gdal-dev] No Spatial Reference System from UTM Ozi .map file
Nik Sands
nixanz at nixanz.com
Sun Nov 11 23:16:07 PST 2012
Is that limitation actually built into GDAL?
Because 2-point .map files are not uncommon, and so long as the two points are both different in both axes, then there should be no reason why a 3rd point in required (especially in UTM).
Cheers,
Nik.
On 12/11/2012, at 6:13 PM, Jean-Claude Repetto <jrepetto at free.fr> wrote:
> On 12/11/2012 05:02, Nik Sands wrote:
>> Please help me figure out why the two sets of .map files behave so differently. In particular, how can I get a spatial reference system for the failing .map files?
>> (Content of two example files are below. First one is OK, second one fails. Let me know if I can provide any further information.)
> Hi,
> I think it is because the second calibration file has only two
> calibration points. Three points are probably necessary.
> Jean-Claude
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
