[gdal-dev] No Spatial Reference System from UTM Ozi .map file
Nik Sands
nixanz at nixanz.com
Mon Nov 12 00:10:41 PST 2012
I will try but don't have any Ozi products and am not confident I can create one that is legitimate. The same may apply to the user who raised the issue but I will check.
On 12/11/2012, at 7:02 PM, Jean-Claude Repetto <jrepetto at free.fr> wrote:
> On 12/11/2012 08:16, Nik Sands wrote:
>> Is that limitation actually built into GDAL?
>> Because 2-point .map files are not uncommon, and so long as the two points are both different in both axes, then there should be no reason why a 3rd point in required (especially in UTM).
>> Nik.
> Have you checked if adding a third point solves your problem ?
> Jean-Claude
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
