[gdal-dev] "reboxing," or 3D regridding
Chris Barker
chris.barker at noaa.gov
Wed Nov 14 15:10:14 PST 2012
Tom,
I'd look for re-gridding code designed for modeling -- in particular
ESMF has a bunch of good stuff, designed specifically for this sort of
thing:
http://www.earthsystemmodeling.org/
They even have python bindings to at lest some of the re-gridding code.
-Chris
On Tue, Nov 13, 2012 at 9:11 PM, Tom Roche <Tom_Roche at pobox.com> wrote:
> summary: I'd appreciate advice regarding tools and methods for
> transforming values from an unprojected global 3D spatial grid to a
> projected 3D grid with different horizontal and vertical resolution, or
> pointers to other resources to consult.
> details:
> I have output from a global atmospheric model that I'd like to use as
> initial and boundary conditions for a regional model. The global input
> netCDF has dimensions=2.5° lon x 1.875° lat x 56 vertical levels. The
> regional model runs over North America using a 12-km grid projected
> Lambert Comformal Conic (LCC), with 34 vertical levels. Since its top
> height is less than that of the global input, the extents of the output
> domain are fully contained within the input domain.
> Each box or voxel defined by the global input grid contains an estimate
> for the N2O concentration for that volume. From those I want to compute
> the concentrations for each output gridbox volume. I'd appreciate your
> recommendations for tools that can handle this usecase. Particularly, is
> this something that gdalwarp can do?
> FWIW, the best tool I've seen so far is R package=gstat, but (IIUC)
> - gstat expects projected input. I'm not sure if I can work around that
> for this usecase.
> - as the name implies, 'gstat' is doing geostatistics, e.g., variogram-
> and covariance-based modeling. I'm not sure either how to setup the
> distance weighting for my scenario, and, frankly, I remain unconvinced
> that a statistical approach is necessary for this application (though
> it may be a sufficient or the best-available approach). This may be
> due to my statistical ignorance, however.
> your assistance is appreciated, Tom Roche <Tom_Roche at pobox.com>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
Chris.Barker at noaa.gov
