[gdal-dev] Problem with gdalsrsinfo on some NOAA bsb/kap files
Chris Barker
chris.barker at noaa.gov
Wed Nov 14 15:16:39 PST 2012
On Wed, Nov 14, 2012 at 3:15 PM, Chris Barker <chris.barker at noaa.gov> wrote:
> On Wed, Nov 14, 2012 at 4:53 AM, Jaak Laineste (Nutiteq)
> <jaak at nutiteq.com> wrote:
>> Have you found workaround for this?
> nope.
>> I just created index bounding boxes for
>> all the NOAA BSB charts using GDAL
> Exacltly how did you use GDAL for this?
>>for my Android solution, see
>> http://imgur.com/MpADB - as you can see there are quite many wrong
>> locations, Xmin-coordinate is 0.
> you mean the huge pile of boxes on the prime meridian?
>> In the same time, Y and Xmax seems to be
>> correct,
> you sure about Xmax -- if that were the case, you'd have a lot of
> charts in Europe... though maybe I don't know what i"m looking at.
>> which is interesting also. I do not have the number, but there
>> seems to be significant number (1/4?) of the NOAA files positioned wrong.
> you might look at a few and see if you can see a pattern.
> GDAL asside, there is a lot of info in the *.kap text header -- I
> think the first few GRPs are the bounds of the "actual" map (i.e.
> without the "collar) for instance. You may be abel to get what youwant
> by directly parsing teh header.
> Not that GDAL shouldn't report the correct values.
> -Chris
> Christopher Barker, Ph.D.
> Oceanographer
> Emergency Response Division
> NOAA/NOS/OR&R (206) 526-6959 voice
> 7600 Sand Point Way NE (206) 526-6329 fax
> Seattle, WA 98115 (206) 526-6317 main reception
> Chris.Barker at noaa.gov
Oceanographer
