[gdal-dev] gdalwarp and mosaic
DmitriyS
sazonov at scanex.ru
Thu Nov 22 02:59:01 PST 2012
Hello, dear developpers. I have one question. I wish to create mosaic image
by the next way. In my output folder threre are two images. the first image
is a mosaic image, and it is created by the command:
gdalwarp.exe -of GTiff -s_srs "+proj=utm +ellps=WGS84 +zone=31 +units=m"
"E:\bug\mosiac\image_1.tif" -overwrite "E:\bug\mosiac\merge.tif"
Then I have to append the second image (without overwriting) to the first
one (merge.tif) using next command:
gdalwarp.exe -"E:\bug\mosiac\image_2.tif" "E:\bug\mosiac\merge.tif".
The output window tells that's ok, merge.tif is done, and does not signal
any mistakes. However as result image_2.tif is not appended, merge.tif has
no changes after this command execution.
Can you say what I should do to append an image to existing image(file)?
Best regards, Dmitriy.
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdalwarp-and-mosaic-tp5018130.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
