[gdal-dev] gdalwarp - Clip raster using mask
Joaquim Luis jluis at ualg.pt
Thu Nov 22 06:02:02 PST 2012
Alisson,
It's not so easy to follow what is "desired" and "not-desired". For an
excellent discussion of the details involved in such operations see
http://blogs.mathworks.com/steve/2006/12/22/poly2mask-and-roipoly-part-3/
As a solution for your 'wish-behavior'  case maybe what you can do is to
previously expand your polygon with a buffer of half cell width.
Joaquim
> Hi friends,
> By using gdalwarp to clip a raster with a mask (shape), I get a new
> raster of smaller size, which is the boundary of the polygon shape
> (mask). However, the pixels do not pass the polygon. I would like to
> pass the pixels just a little of the polygon mask.
> For clarity, I send two pictures of what I desire and not desire:
> http://postimage.org/image/hlrc3911z/
> http://postimage.org/image/4vn3q5t3r/
> The used command is: gdalwarp -dstnodata 0 -q -cutline
> C:/Users/Hugo/Final.shp -crop_to_cutline -of GTiff
> C:/Users/Hugo/Elevation-DEM-CLIPPED.img
> Can you help me?
> Best Regards,
> Alisson Barbosa
> Systems Analyst - FUNCEME
> M.Sc. in Computer Science - MACC
> Graduate in Computer Science  - UECE
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121122/619c6d83/attachment.html>
