[gdal-dev] ogr2ogr & gdalinfo both crashing on 64-bit Windows 7, very little info available
Ivan Lucena
ivan.lucena at princeton-ma.us
Thu Nov 22 16:06:08 PST 2012
Is your Oracle 64 or 32? Was GDAL build to 32 or 64? (It looks like you are using OSGeo4W so it must be 32) I have seem that same kind of problem and it was because the oci.dll from the Oracle 64 was first on the PATH instead of the oci.dll 32 bits that comes with OSGeo4W. Try to clean up the PATH environment adding only the essential, as it is needed. You might use MS File Mionitor to know more about what is going on. Also try to enter the database instance name on "oci:user/pwd at dbinstance". You can also try the GDAL build for 64bit from gisinternals/sdk with Oracle support. Works great.
> -------Original Message-------
> From: cheesybiscuits <thomaschristian at gmail.com>
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] ogr2ogr & gdalinfo both crashing on 64-bit Windows 7, very little info available
> Sent: Nov 22 '12 18:08
> When I run ogr2ogr or gdalinfo (and maybe other tools, I've never used the
> others) I always get a crash. I'm using Windows 7 64-bit and gdal 1.9.2. The
> only information I get from Windows Event Viewer looks like this:
> ogr2ogr.exe
> 0.0.0.0
> 50981d19
> ntdll.dll
> 6.1.7601.17725
> 4ec49b8f
> c0000374
> 000ce6c3
> 544
> 01cdc9024472ef70
> c:\OSGeo4W\bin\ogr2ogr.exe
> c:\Windows\SysWOW64\ntdll.dll
> 84cba12d-34f5-11e2-8214-002713b231b3
> As you can see I'm on a 64-bit system. I assume this is part of the problem
> somehow.
> gdalinfo --formats lists some formats and then crashes. I don't know if it
> crashes before listing all formats or after they're all displayed. ogr2ogr
> crashes before generating any output. Both commands have been run as both
> regular user and administrator with no difference.
> I put c:\OSGeo4W\bin at the beginning of the PATH, and I am executing my
> command from the 32-bit CMD prompt, but based on the error report I think
> some part of the process is calling 64-bit ntdll.dll.
> It might be relevant - I also installed gdal Oracle support. I'm fairly
> confident this is working as the first time I ran ogr2ogr it complained my
> TNS entry didn't exist. After I updated the TNS it stopped complaining (then
> crashed). If I was only seeing crashes in ogr2ogr I'd assume there was an
> issue with Oracle or my SQL, but gdalinfo is also having problems.
> This is my ogr2ogr command: ogr2ogr -f "CSV" c:\users\me\Desktop\test.csv
> OCI:user/pass at tnsname -sql "select id from table"
> Any thoughts or suggestions very much appreciated. I thought maybe I could
> pass an argument telling the entire process to run as 32-bit but Google
> isn't giving up the goods.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/ogr2ogr-gdalinfo-both-crashing-on-64-bit-Windows-7-very-little-info-available-tp5018255.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
