[gdal-dev] OpenJPEG 2.0 released
Angelos Tzotsos gcpp.kalxas at gmail.com
Mon Nov 26 01:51:30 PST 2012
On 11/26/2012 10:29 AM, Even Rouault wrote:
> Selon Angelos Tzotsos <gcpp.kalxas at gmail.com>:
>> On 11/20/2012 09:23 PM, Even Rouault wrote:
>>> Hi,
>>> Just to inform you that the OpenJPEG project has just released OpenJPEG
>> 2.0.0.
>>> GDAL users of GDAL 1.10dev that need support for JPEG2000 can (must) now
>> rely
>>> on a released version, and no longer on the openjpeg SVN v2 branch (which
>> has
>>> been removed by the way)
>>> Even
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Hi Even,
>> openjpeg-2.0 final has just been upgraded in openSUSE, causing
>> gdal-1.9.2 build to break.
> Yes this is expected. OpenJPEG 2.0 API has been changed during the merge of
> their v2 feature branch into their trunk.
>> Is there a patch available to apply or should I disable openjpeg until
>> gdal-1.10 release?
> I don't foresee doing a patch at this point of GDAL 1.9.X lifetime to bring
> support of OpenJPEG 2.0. You could decide shiping the old v2 branch of openjpeg
> in the state it was, but I doubt that you'll do this for a distribution since it
> would be a bit confusing. So yes the best is probably to wait for GDAL 1.10.
>> Best,
>> Angelos
>> Angelos Tzotsos
>> Remote Sensing Laboratory
>> National Technical University of Athens
>> http://users.ntua.gr/tzotsos
Thanks Even,
I have disabled openjpeg2 support until 1.10.
Cheers,
Angelos
Angelos Tzotsos
