[gdal-dev] CRS not defined with BMP
Etienne Tourigny
etourigny.dev at gmail.com
Wed Nov 28 09:29:30 PST 2012
As far as I know, bmp files (like jpeg and gif and probably others)
only support "ESRI World files". This is not a true CRS definition
though, it only indicated the geotransform.
Even though it is not standard, it would be convenient to update these
drivers to read an associated .prj file
http://www.gdal.org/frmt_bmp.html
http://en.wikipedia.org/wiki/World_file
cheers,
Etienne
On Mon, Nov 26, 2012 at 11:23 AM, Clay, Bruce <bclay at ball.com> wrote:
> I am using GDAL to convert CADRG files to BMP chips for an application
> written to only use BMP. I have created the BMP chip, BMP world file and a
> 4326 prj file to indicate WGS 84. When I use gdalinfo to look at the
> settings it always indicates CRS is not defined. QGis also says the CRS is
> not defined. Is there a proper way to define a CRS for rasters that rely on
> a world file?
> Bruce
> This message and any enclosures are intended only for the addressee. Please
> notify the sender by email if you are not the intended recipient. If you
> are
> not the intended recipient, you may not use, copy, disclose, or distribute
> this
> message or its contents or enclosures to any other person and any such
> actions
> may be unlawful. Ball reserves the right to monitor and review all messages
> and enclosures sent to or from this email address.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
