[gdal-dev] 64bit integers
Jürgen E. Fischer
jef at norbit.de
Thu Nov 29 13:36:54 PST 2012
Hi Even,
On Thu, 29. Nov 2012 at 20:53:57 +0100, Even Rouault wrote:
> With latest trunk, you can set the OGR_SETFIELD_NUMERIC_WARNING configruation
> option to YES. This should generate a warning if the conversion to int
> overflows.
Um, that was meant to produce a warning when a non-numeric (or partly numeric)
string is parsed incompletely to a number. Overflows are not yet covered (we
don't reset and check errno for ERANGE after the conversion).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
committ(ed|ing) to Quantum GIS IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
