[gdal-dev] 64bit integers
Jeremy Palmer JPalmer at linz.govt.nz
Thu Nov 29 14:10:08 PST 2012
Thanks.
Any idea if the 64bit proposal is going to happen any time soon?
If not, is there an option to implement functionality to cast 64bit fields to string in 1.9.X? This function could still be useful once 64bit integers are implemented.
Cheers
Jeremy
----- Original Message -----
From: Even Rouault <even.rouault at mines-paris.org>
To: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
Sent: 30/11/2012 10:45 AM
Subject: Re: [gdal-dev] 64bit integers
Le jeudi 29 novembre 2012 22:36:54, Jürgen E. Fischer a écrit :
> Hi Even,
> On Thu, 29. Nov 2012 at 20:53:57 +0100, Even Rouault wrote:
> > With latest trunk, you can set the OGR_SETFIELD_NUMERIC_WARNING
> > configruation option to YES. This should generate a warning if the
> > conversion to int overflows.
> Um, that was meant to produce a warning when a non-numeric (or partly
> numeric) string is parsed incompletely to a number.   Overflows are not
> yet covered (we don't reset and check errno for ERANGE after the
> conversion).
Those checks are now done per http://trac.osgeo.org/gdal/changeset/25265
> Jürgen
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
