[gdal-dev] MSSQL Spatial and 3D issue
ngarel ngarel at micromine.com
Thu Nov 29 23:16:02 PST 2012
Thanks for that...I tried all different formats and looked into your changes.
Could not retrieve my Z coordinate using wkb format because you created a
new geometry format called *wkbzm*.
Please update the doc (http://www.gdal.org/ogr/drv_mssqlspatial.html) and
don't forget to specify that wkbzm is only available for SQL Server 2012:
AsBinaryZM() does not exist in sql server 2008 see error thrown below:
Could not find method 'AsBinaryZM' for type
'Microsoft.SqlServer.Types.SqlGeometry' in assembly
'Microsoft.SqlServer.Types'
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-dev-MSSQL-Spatial-and-3D-issue-tp4892552p5019794.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
