[gdal-dev] TIFF overviews issue
Fabian Schindler
fabian.schindler at eox.at
Fri Nov 30 07:21:59 PST 2012
Dear devs,
I'm experiencing an strange issue concerning overviews when I try to add
overviews via Python. Essentially I want to create overviews for
Greyscale images encoded in RGB, but on one overview level I always get
colored pixels in a specific rectangle area of the image.
I created the boiled down test script to demonstrate what I am doing
(create RGB grey image of certain size, save it to disk and apply
overviews) which is available in the attachment. The script is called
like that: `python test_overviews.py out.tif`
In my case I could see the colorfull overviews in QGIS (or MapServer
WMS) if I zoomed out a little. A screenshot of QGIS with the image can
be found in the attachment.
Strangely, I only have this issue on CentOS 6.3 (gdal 1.9.1, libgeotiff
1.4.0, libtiff 3.9.4) but not on my host Ubuntu 12.10 system (gdal
1.9.2, libgeotiff2 1.3.0, libtiff 4.0.2).
I tried different interpolation methods for the `BuildOverviews`
function, with no effect. If I remove the level `2` or `4` from my level
list, the effect does *not* show. A different image size results in a
different colour and position of the rectangle and sometimes the
rectangle is not visible at all.
The issue is the same when I use `gdaladdo out_no_ovr.tif 2 4 8 16`.
Any idea on this?
Regards,
Fabian
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121130/9580c40c/attachment.png>
Type: text/x-python
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20121130/9580c40c/attachment.py>
