[gdal-dev] Problem installing gdal from source - dxf-related?
Andreas Neumann a.neumann at carto.net
Mon Oct 1 05:52:31 PDT 2012
 I tried to test the latest DXF fixes - but get an error message during
 installation. The compile works fine, but during install I get the
 following message:
 make[3]: Entering directory `/home/an/dev/gdal/ogr/ogrsf_frmts/dxf'
 /bin/bash /home/an/dev/gdal/libtool --mode=compile --tag=CXX g++ -g -O2
 -Wall  -I.. -I../.. -I/home/an/dev/gdal/port -I/home/an/dev/gdal/gcore
 -I/home/an/dev/gdal/alg -I/home/an/dev/gdal/ogr
 -I/home/an/dev/gdal/ogr/ogrsf_frmts -DOGR_ENABLED
 -I/home/an/dev/gdal/port  -c -o ../o/ogrdxfwriterlayer.lo
 ogrdxfwriterlayer.cpp
 libtool: compile:  g++ -g -O2 -Wall -I.. -I../..
 -I/home/an/dev/gdal/port -c ogrdxfwriterlayer.cpp  -fPIC -DPIC -o
 ../o/.libs/ogrdxfwriterlayer.o
 ogrdxfwriterlayer.cpp: In member function 'OGRErr
 OGRDXFWriterLayer::WritePOINT(OGRFeature*)':
 ogrdxfwriterlayer.cpp:384:1: error: a function-definition is not
 allowed here before '{' token
 ogrdxfwriterlayer.cpp:332:19: warning: unused variable 'poTool'
 [-Wunused-variable]
 ogrdxfwriterlayer.cpp:1178:1: error: expected '}' at end of input
 ogrdxfwriterlayer.cpp:1178:1: warning: control reaches end of non-void
 function [-Wreturn-type]
 make[3]: *** [../o/ogrdxfwriterlayer.lo] Error 1
 make[3]: Leaving directory `/home/an/dev/gdal/ogr/ogrsf_frmts/dxf'
 make[2]: *** [dxf-target] Error 2
 make[2]: Leaving directory `/home/an/dev/gdal/ogr/ogrsf_frmts'
 make[1]: *** [sublibs] Error 2
 make[1]: Leaving directory `/home/an/dev/gdal/ogr'
 make: *** [ogr-target] Error 2
 Tonight I will test on a different machine to see if the problem is
 reproducible.
 Thank you if you have any idea how I can fix the problem,
 Andreas
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
