[gdal-dev] Regarding Attribute corruption while reading KML file
Even Rouault
even.rouault at mines-paris.org
Mon Oct 1 14:03:26 PDT 2012
Le lundi 01 octobre 2012 22:37:48, Abhinav a écrit :
> I am having Issue in reading attributes of kml file with Gdal.
> When I am running gdalinfo in windows, it displays
> Had to open data source read-only.
> INFO: Open of `D:\Users\DMS\Desktop\Airbase.kml'
> using driver `KML' successful.
> 1: AIR_FIELD (3D Point)
> Is it the right driver for the windows?
Extended schema is only support by the LIBKML driver ( see
http://gdal.org/ogr/drv_libkml.html ), but it is likely not included in your
GDAL binary distribution, otherwise the file would have been opened by it.
Anyway, in my own GDAL build that includes the LIBKML driver, I don't manage
to get the extended attributes. The reason is that this file is not a valid KML
2.2 file (in the sense, it doesn't validate against the OGC KML 2.2 schema at
http://schemas.opengis.net/kml/2.2.0/ogckml22.xsd ). The issue is that the
<Schema> ... </Schema> declaration is inside the <Folder> element, instead of
being right under the <Document> element.
Once this is corrected in a text editor, the LIBKML driver can read the
attributes :
$ ogrinfo Airbase.kml -al
INFO: Open of `Airbase.kml'
using driver `LIBKML' successful.
Layer name: AIR_FIELD
Geometry: Unknown (any)
Feature Count: 1
Extent: (82.686300, 22.204900) - (82.686300, 22.204900)
Layer SRS WKT:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AUTHORITY["EPSG","4326"]]
description: String (0.0)
timestamp: DateTime (0.0)
begin: DateTime (0.0)
end: DateTime (0.0)
altitudeMode: String (0.0)
tessellate: Integer (0.0)
extrude: Integer (0.0)
visibility: Integer (0.0)
drawOrder: Integer (0.0)
icon: String (0.0)
Description: String (0.0)
Affiliation: Integer (0.0)
Plan: Integer (0.0)
ColorR: Integer (0.0)
ColorG: Integer (0.0)
ColorB: Integer (0.0)
ColorA: Integer (0.0)
LineWidth: Integer (0.0)
IconSize: Real (0.0)
AutoSwitch: Real (0.0)
Representation: Integer (0.0)
RotationX: Real (0.0)
RotationY: Real (0.0)
RotationZ: Real (0.0)
ScaleX: Real (0.0)
ScaleY: Real (0.0)
ScaleZ: Real (0.0)
AAS_CODE: Integer (0.0)
AFDALTITUDE_IN_M: Real (0.0)
AFD_ACTYPE: String (0.0)
AFD_ADINFO: String (0.0)
AFD_ID: String (0.0)
AFD_NAME: String (0.0)
AFD_SECTOR: String (0.0)
AFD_TYPE: String (0.0)
AF_UNIT: String (0.0)
ASSOCIATEDWITH: String (0.0)
CONTROL_TOWER: Integer (0.0)
DATE_TIME: String (0.0)
DP_DAY_NI: String (0.0)
FORFMNUNIT: String (0.0)
HANGER_CAPACITY: Integer (0.0)
KEYID: Integer (0.0)
LOC_CONT_TOWER: String (0.0)
LOC_FUEL_TKS: String (0.0)
LOC_LAT: String (0.0)
LOC_LONG: String (0.0)
LOC_RDR_STN: String (0.0)
NO_OF_RUNWAYS: Integer (0.0)
PHOTOGRAPHS: String (0.0)
REFUEL_CAPACITY: Real (0.0)
RW_BEARING: String (0.0)
RW_LENGTH_IN_M: Real (0.0)
RW_SURFACE: String (0.0)
RW_WIDTH_IN_M: Real (0.0)
VA_VP_INFO: String (0.0)
OGRFeature(AIR_FIELD):1
Name (String) = A2
description (String) = (null)
timestamp (DateTime) = (null)
begin (DateTime) = (null)
end (DateTime) = (null)
altitudeMode (String) = (null)
tessellate (Integer) = -1
extrude (Integer) = -1
visibility (Integer) = -1
drawOrder (Integer) = (null)
icon (String) = (null)
Name (String) = (null)
Description (String) = (null)
NAME (String) = (null)
Affiliation (Integer) = 1
Plan (Integer) = 1
ColorR (Integer) = 255
ColorG (Integer) = 0
ColorB (Integer) = 0
ColorA (Integer) = 255
LineWidth (Integer) = 11
IconSize (Real) = 12
AutoSwitch (Real) = 51
Representation (Integer) = 5
RotationX (Real) = 13
RotationY (Real) = 14
RotationZ (Real) = 15
ScaleX (Real) = 16
ScaleY (Real) = 17
ScaleZ (Real) = 19
AAS_CODE (Integer) = 1
AFDALTITUDE_IN_M (Real) = 2
AFD_ACTYPE (String) = 3
AFD_ADINFO (String) = 4
AFD_ID (String) = 5
AFD_NAME (String) = 6
AFD_SECTOR (String) = 7
AFD_TYPE (String) = 8
AF_UNIT (String) = 9
ASSOCIATEDWITH (String) = 10
CONTROL_TOWER (Integer) = 11
DATE_TIME (String) = 12
DP_DAY_NI (String) = 13
FORFMNUNIT (String) = 14
HANGER_CAPACITY (Integer) = 15
KEYID (Integer) = 16
LOC_CONT_TOWER (String) = 17
LOC_FUEL_TKS (String) = 18
LOC_LAT (String) = 19
LOC_LONG (String) = 20
LOC_RDR_STN (String) = 21
NO_OF_RUNWAYS (Integer) = 22
PHOTOGRAPHS (String) = 23
REFUEL_CAPACITY (Real) = 24
RW_BEARING (String) = 25
RW_LENGTH_IN_M (Real) = 26
RW_SURFACE (String) = 27
RW_WIDTH_IN_M (Real) = 28
VA_VP_INFO (String) = 29
POINT (82.6863 22.2049 0)
