[gdal-dev] OGR SQL: Excecuting select where column name contains "."
Odd Ragnar Lydersen Odd-Ragnar.Lydersen at powel.no
Thu Oct 4 23:45:28 PDT 2012
When I use single quotes, I get no errors, but instead I get returned the column name = FIELD_1, and all values = column.name.one
I'm using the ExecuteSql() on a WFS datasource, so it might be the WFS driver which causes the undesired FIELD_1 result.
>Odd-Ragnar<
-----Original Message-----
From: Jeff Lake [mailto:admin at michiganwxsystem.com]
Sent: 4. oktober 2012 14:11
To: Odd Ragnar Lydersen
Subject: Re: [gdal-dev] OGR SQL: Excecuting select where column name contains "."
use single quotes
eg 'column.name.one'
-Jeff Lake
MichiganWxSystem.com
AllisonHouse.com
TheWeatherCenter.net
GRLevelXStuff.com
On 10/4/2012 7:29, Odd Ragnar Lydersen wrote:
> Is it possible to make OGRDataSource:: ExecuteSQL() to work with a column name containing "."?
> Here is an example:
> select column.name.one, column.name.two from 'wfs:layerName'
> I have tried to enclose the column name in [] brackets, but that was invalid as well.
> Any ideas on how to get around this?
>> Odd-Ragnar<
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
