[gdal-dev] OGR SQL: Excecuting select where column name contains "."
Even Rouault even.rouault at mines-paris.org
Fri Oct 5 09:39:08 PDT 2012
> To follow SQL, it is recommended to you double-quote
> characters,
> > which might require SHELL escaping since they are already in a
> double-quoted
> > string, like :
> Yes, that's a good theory but it is not easy to use it on Windows. Does
> anybody in the world know how should this one be escaped? I have
> already tried to use ^" as inner double quotes but without success,
> as well as having two ^^ and three ^^^.
Doh! my webmail client has changed what I have typed ! To escape double-quote in
Windows shell, you need to put a backslash character before them.
